Connecting Javelin to a GPS sensor (USB male)
I'd like to connect a GPS receiver to my Javelin to be able to read GPS coordinates. The GPS reciever (check this website www.gpsoz.com.au/global_sat_usb.htm) has a male USB connector and my problem is that I don't know how to connect them together. I was thinking that maybe using a RS232 to USB (female) adapter will fix my problem, but I can't find such a convertor anywere. Have anyone any idea about this?
/Paul
Post Edited (Paul Edfeldt) : 10/18/2005 7:00:12 AM GMT
/Paul
can not connect that device to the javelin.
Try to find a serial based gps receiver. Those you can connect to
the javelin.
regards peter
http://www.acroname.com/robotics/parts/R217-TR-GPM.html
It has a serial output mode, but we're still fiddling with the details so I'm not 100% sure it would work for exactly what you want. Good luck with the project.
Good luck with your project.
