temperature on LCD
Hi all,
I have the NX-1000 24/40 board with the the StampWorks book (kit).
I was working on experiment #28 and at the end of that experiment there is a challenge to make it work with the LCD module.
The experiment was about temperature measurement with the DS1620.
I first made the connections (see image attachment), then I wanted to merge the LCD (ex#11) code with the temperature measurement (ex#28) code.
This did not go as I planned
In the attachment (file) you can see what I dit, this is not the only thing I have tried. I did some more drastic things to, but they also failed.
I am no programmer and nog technician, so I have to learn allot, but I like it so I want to learn.
If someone could help me out with this problem and also explain one thing or two that would be great.
thanks in advance
Aaron
thanks in advance
Aaron
Jon Williams
I am a real newbie, I even have to figure out what each symbol stands for and how to connect everything, but with the help of internet I am learning that to.
thanks
Aaron
Jon Williams
thanks for the help and info
Aaron
This is not directed "at" you Aaron, it just happens that you started this thread
Please take a look at the separate topic I started, entitled "The Parallax Advantage". After reading it, I suspect you'll better understand why we all encourage self-learning through the materials that Parallax has to offer. You'll never regret it, whether you view "Stamping" as just a hobby or as something more than that.
Bruce Bates
