220 Ohm resistor from each I/O line? y/n?
Hi, I'm setting up my own prototyping breadboard and I was wondering if i should add a 220 ohm resistor from each I/O leg of the stamp to my breadboard (where i will be plugging in leds, sensors, servos, etc). I read somewhere that this is supposed to protect the stamp from accidental miswiring? is this true? Is the value of 220 ok for all legs, or do i need to "calculate" a specific value for each separate application?
So, to add them is up to you and what you think your experience level is. Resistors are often called "current limiters" -- I also call them "cheap insurance."
Jon Williams
It would be better just to use them in a breadboard until you feel that you no longer need them or want to change the value. Some circuits, like the Resistor-Capacitor combinations may work well with them, but others may need to add 10,000 ohms., some may add 1,000 ohms, and some LED circuits put the LED directly to the Stamp and the 220ohm [noparse][[/noparse]or 330ohm or 470ohm] between the LED and +5 volts.
As you learn the math [noparse][[/noparse]and concepts], you will begin to see why.
There is another way to protect the BasicStamp for outputs that may drain too much. You can put a 74HC07 'hex buffer' between the Stamp and the device. If you are wrong, the 74HC07 will suffer the damage, not the STAMP. It allows for six I/O pins.
Jon has written a lot of Nuts n' Volts articles that really explain these things. They are on-line and Free for you to read. Also, you can download a copy of 'What's a Microcomputer?' and use that to guide you through quite a lot of information.
Post Edited (Kramer) : 10/16/2005 2:37:37 PM GMT
