Super carrier board-where to connect battery?
If i run a rechargeable 6v battery pack, do i just hook it up to the connector for the 9V or do i hook it up to the plug for the power supply? Does it matter, or is there no difference between the two?
Also, the "Vdd" on the board, is there anyway to have that power come directly from the battery (i will need a higher current draw than the stamp provides)? Or do i need to get another "power bus" (i think thats what its called)
Thanks.
Thanks.
Jon Williams
Schematic: http://www.parallax.com/dl/docs/prod/schem/supercarrierbd.pdf
Jon Williams
