Distance sensors
I need a distance sensor that has around the sensing capabilities of this:
http://www.sickusa.com/live/master/datasheet.asp?PN=1015850&FAM=Measurement&P=4182
but·is more affordable (less than $200 instead of over $5000). It's fine if I need to mount it on a servo to get a sweep. And I would actually prefer raw data instead of the sensor doing all of the calculations for me. Can anyone help?
http://www.opticsplanet.net/opti-logic-range-finder-rs100.html
but a little more than twice what you wanted to pay, about $500. I think that the solution here is to buy a lower end consumer device and see if you can hack it. I'l see what else I can come up with.
In case it helps, here's what I'm trying to do: I need to get a robot to build a map of its environment to help a team of robots navigate. I would use ultrasonic sensors, like the PING))), but as far as I can tell those just see whatever is closest in a cone. I need the sensor to be able to distinguish between multiple points in a small area, because it's going to have very small objects that it needs to place on its map.
·1+1=10
<Embarrassed>didn't know about the things and stuff</embarrassed>
Post Edited (Benjamin_baker) : 11/15/2005 4:58:53 AM GMT
