Controlling PSC with externally generated files? Importing?
All--
I am interested in executing a externally generated file with PSC operated via a PC. I'm sure there are many different ways to do this, but ideally I would like to use excel to generate a long table of time steps and servo positions, export that as a simple space delineated text file and import that file into PSC-USB software.
I don't think that is possible, but perhaps it is possible to use a serial connection to a PSC and send the generated commands (!SC, C, R, PW, $0D) with a HyperTerminal type program?
I am aware i could program a stamp with small for-loop/serout program, but for this project i would like to change the list of commanded positions and time steps quickly using fairly complicated math.
I’d appreciate any ideas or suggestions.
jeff
jeff
Jon Williams
I was afraid of that... furthermore, i would need fairly precise timing (on the order of 10 msec) and i gather windows just isn't that accurate. I suppose the easiest custom application would be a dedicated microcontroller--something with an oscillator?
is it practical then, to store my list of time steps and servo positions in a chip's RAM? i'm looking at storing 1000 entries, each entry consisting of a time step of 0 to 1000 and a corresponding servo position of 0 to 255. is it practical to store this table in a chip, or is it a better practice to generate each valve pair in a for-loop on the fly?
Thanks for your time,
jeff
Jon Williams
