Using Stache ( BASIC Stamp F.Programmer) to collect info. from the Stamp and u
I have a Basic stamp 2 homework collecting temperature of my car engine.
I need to know if I can use the Stache ( BASIC Stamp Field Programmer)
to take the basic stamp temperature (using a DS1620) and download the temperatures to my PC
I don't want to take out the basic stamp from my car.
I read that the Stache ( BASIC Stamp Field Programmer) is used
to download from a computer and then upload the program to a Basic Stamp ,
, but , I need to download from a Basic Stamp
and then upload my PC.
I this possible?
Is there an other item at Parallax instead of the Stache ( BASIC Stamp Field Programmer) ?
Thanks: Markus
I this possible?
Thanks: Markus
Sid Weaver
Do you have a Stamp Tester yet?
·· You could be the one to build one!·
csavage@parallax.com
And , do you know if can use a the Stache to transffer the temperature collected
from Stamp Nº1 to a second Stamp and this second stamp connected to a computer?
LIKE this:
STAMP Nº1 (collecting temperature) ----> Stache ----> Stamp Nº2 connected to a PC.
Sid Weaver, Is this possible because you told that: "The Stache will only work Stamp to Stamp".
Thanks again: Markus
Sid Weaver
·· Complete documentation for the Stache can be found at the following web page.
http://www.parallax.com/detail.asp?product_id=27330
Are you from Parallax ?
I am asking this becuase it seems that you know a lot about the Stache device.
But about your answer, perhaps your help, could be usefull when you told that
it is possible to collect the data from the EEPROM.
The problem I have is that there is not explanation about that,
even reading the pdf about the Stache device.
Do you know where can I find more information?
Thanks, Markus
Read the Stache documentation very carefully, then read it again.· And just remember, anything that is stored in a Stamp module can be uploaded to the Stache.
Sid Weaver
You might consider using Stamp Plot which will not only plot the data (if you wish) but you can store it for later retrieval by another program. Stamp Plot comes in two versions, Lite which can be directly downloaded, and Pro, which has all the bells and whistles, and comes on a CD. Here is a link to the software:
http://www.parallax.com/html_pages/downloads/software/stamp_plot_pro_info.asp
Alternative to that, you might want to look at StampDAQ as well. StampDAQ will dump the data it receives via a serial connection right into an Excel Spreadsheet. The data can be exported from Excel in many different formats. StampDAQ is free for the download from here:
http://www.parallax.com/html_pages/downloads/software/software_stampDAQ.asp
Just a couple of inexpensive but expeditious methods of gathering data from a Stamp.
Bruce Bates
Sid and others here have already answered your question, I think. The purpose of the Stache is one way only, it takes in a program or several different programs and data from the PC running STAMPW.EXE. Then you carry the Stache to a field site and plug the Stache into the Stamp system, press a button, and the program is loaded into the Stamp there. It does not work the other way around. You cannot load your acquired data from the Stamp onto the Stache and carry that back to the PC. Like Chris said though, that is a useful function.
There has been talk here from time to time about using memory cards for that purpose, but there are several issues that have to be overcome to make that practical.
If you have a second BASIC Stamp with enough memory (how much do you need?), you could create your own shuttle module. Stamp #2 shuttles data from Stamp #1 to the PC, where you could use the tools Bruce mentioned like StampPlot or StampDAQ to analyze the data.
If you have further questions about the Stache, i would be happy to anser them, because it is my baby.
Tracy Allen
www.emesystems.com
If you hdn't already figured it out, Tracy Allen (who posted above) is the creator of the Stache device.
I realise that you're trying to make sure the information that you are getting is accurate, if anyone would know it would certainly be Tracy Allen. [noparse]:)[/noparse]
Also, any employees of Parallax have the Parallax name in their name.
Knight.
If you have a Palm PDA, it is relatively easy to transfer the data from the stamp serially to the Palm, and thence to your PC. You will need a serial download cable for the Palm device, a null modem adapter and a gender-bender- all available for about 8 bucks at the Rat Shack. I wrote a little app a few years ago that is essentially "HyperTerm for Palm," and is designed to debug a Stamp in the field. You could just save the outputted data and move it to the PC when you synch.
peter
Peter C. Charles
Director, Research and Technology
CyberBiota, Incorporated
Peter.charles@cyberbiota.com
http://www.cyberbiota.com
I would be interested in your ideas regarding HyperTerm for Palm, and using it with the Stamp BS2 in the field. You can contact me PM if desired.
I will not use the stache bercause it seems it is not clear yet
I will study ( thanks,Sid Weaver)
Perhaps I can use a second Basic stamp to load the stamp number
one has collected. ( Is that ok Tracy Allen ? )
And connect the second basic stamp to the computer
and use stamp daq or stamp plot.
( Am I ok now ? )
My english is not good , sorry.
thanks Markus.
If I correctly inderstand what you are trying to do, then it sounds like the easiest thing to do will be to use another Stamp. You will have to adjust the code on the "car" stamp to allow being queried via a serial request on one of its pins and then it can send the data out on that pin to your requesting Stamp. This shouldn't add too many lines of code to your temperature gathering stamp and use only 1 pin.
HTH.
