Ram and BSII
Hello,
Is there any way to store serial data from a sensor to a ram chip using the BSII.
Curtis
Curtis
Jon Williams
I built a small datalogger to record experimental data and I would like to store in somewhere like a ram chip in order to download it in the field via a cable and a palm computer. I have wrote the DAQ software for the palm already.· I will test it with a VB 6 program. I would eventially like to use usb. Right now I am using a BOE.
Curtis
Jon Williams
I'll look on the Parallax site and read up how to use I2C. I'll also order a DS1307.
Curtis
·1+1=10
I have been looking on the Parallax site and I was thinking about ordering the Professional development board and a BS sp stamp so I can experiment. Would this allow me to have everything I need to test my project?
Curtis
·1+1=10
Curtis
<edit> I wouldn't store data in ram, I would want it in non-volatile memory in case the power is cut (purposly or accidentally) you wont loose the data </edit>
·1+1=10
Is there any info on how to interface an external eeprom to a bsII until my order is done?
Curtis
Jon Williams
Jon Williams
http://www.parallax.com/dl/docs/prod/oem/24lc128.pdf
http://www.parallax.com/dl/docs/cols/nv/vol5/col/nv115.pdf
http://www.parallax.com/dl/docs/prod/acc/pluspackmanual.pdf
And if you have a Stamp that has built in I2C commands look at this reference which has code for both the EEPROM and real-time clock chip:
http://www.parallax.com/dl/docs/prod/stamps/bs2p24starterkit.pdf
theres more links, but more info may just confuse you.
·1+1=10
Post Edited (Paul Baker) : 10/13/2005 8:11:03 PM GMT
Rafael
·1+1=10
