14-pin developement board connector + cable
Hi All,
I have a Parallax Professional Developement Board (PDB). It has a 14 pin connector (dual row of 7 pins). It might also go by the names : 14-pin header, 14-pin box header, 14-pin socket, etc.
It is just like the· 20 pin header (dual row of 10 pins) on the Super Carrier Board except for the size & pin count.
My question : I am looking for the socket that will plug into my 14-pin connector on the PDB. I want the connector to have a ribbon cable attached to it (e.g. 12 inches or more).
Can anyone please provide vendors + links to such a product.
Thanks in advance.
Thanks in advance.
Sid Weaver
Do you have a Stamp Tester yet?
PS : I forgot to include this.
Here is a hi-res picture of the Professional Developement board :
http://www.parallax.com/images/prod_jpg/28138-HUGE.jpg
The 14-pin connector is in the upper right corner.
Thanks.
Ooops ..... error in my original post.
The connector on the Professional Developement Board (PDB) is not like the one on the Super Carrier Board (SCB). The PDB has a male connector & the SCB has a female one.
Regards.
·· That connector is used for LCD connections, and really won't be much use for anything else due to internal connections.· We do have an LCD Display which connects to that header using a ribbon cable· It can be found at the following web page.
http://www.parallax.com/detail.asp?product_id=603-00006
csavage@parallax.com
There is also a type that will work that uses crimp pins instead of idc, but that would·be 14 individual wires, not a ribbon cable.
Mr. Sid Weaver your advice was the best for me. I called DigiKey & was connected w/ a knowledgeable tech in a couple of minutes. The tech found the connector + cable in in less than 3 minutes. It was painless.
Richard
