Serout question ...
I am having trouble connecting to my stamp through a hyperterminal. I have code that uses serout to port 16 (which I thought was the output to a terminal) however nothing shows up when connected to the proper com port. I have to use the debug command now in order to send any data to the stamp. How do I configure the hyperterminal?
I'm sorry if this has been asked before or covered elsewhere, I went through quite a few forum pages with no luck.
THank You
THank You
Hyperterminal should work, although it can be a bit more tempermental than say, Procomm.
Obviously, make sure the speed and other parameters are set properly. Also, go into Properties on Hyperterm and set the handshaking to "none" .
You should be able to use just a 3-wire cable ( pins 2, 3, 5) and get data across. I don't have the docs in front of me, but it may be necessary for pin 2 on the stamp connector to go to 3 on the computer connector and vice versa.
Start with a simple serout command and put it in a loop sending "hello" ,for example, every couple of seconds.
Good luck.
Tom Sisk
Start with DEBUG to get things going; after that you can use SEROUT to "pin" 16.· When using DEBUG you will set Hyperterminal for 9600 baud (unless you're using a BS2px which uses 19.2K).· A simple program like this will get you going:
theCount··· VAR·· Byte
Main:
· DEBUG "Hello·· ", DEC theCount, CR
· PAUSE 1000
· GOTO Main
Jon Williams
Jon Williams
