shift registers to bs2
I am working on· an application which requires a shift register connection (serial side) to a BS2. I am looking at the
TI TLV5618. Has anyone done this ?·Can you direct me to some information which describes the process?
It looks straight forward based on what I am seeing on the TI site, but I have been caught in that trap before.
Thanks.......
Thanks.......
·· Are there some special requirements in a shift register that you have where a standard 74HC595 or 74HC165 won't work?· 74HC595s for example, can be daisy chained using 3 I/O lines and give 8, 16, 24 or more outputs.
csavage@parallax.com
http://forums.parallax.com/showthread.php?p=550065
(Chris, the TLV5618 is a 2 channel, 12 bit DAC with SPI interface)
It looks like it should be easy to get it working, but as you will see, if you follow the thread, the questioner was having quite a few difficulties with it. I've ordered a sample of one myself to check it out. I also posted working code there for the MAX5722, which is a similar chip from Maxim.
Tracy Allen
www.emesystems.com
http://forums.parallax.com/showthread.php?p=552892
