Waxing digital with electronic wicks
I read the artical in nuts and volts magazine about making a candle with a BS1 and some LED's. Maybe I missed something in the article but is it possible to accomplish the same thing with a bs2? If so could I be able to translate the code from the magazine into something the bs2 would understand or is it pretty difficult? I have no knowledge of bs1 programming and not too much knowledge with the bs2 yet.
thanks for the help.
~Jeremy
~Jeremy
Jon Williams
~Jeremy
I can whip up a BS2 example, and will do that sometime today. Other that that, I don't know what else to do as the article shows the connections and even gives directions for building the candles.
As for what I did for Brian, all I sent him was code and he connected the LEDs on his own.· There is far more presented in Nuts & Volts than I sent to him.
Jon Williams
~Jeremy
Sorry, the last couple weeks have been a blur for me, traveling for work and looking for a new home in southern California· -- and today when I sat down to convert the code... I found I already had!··As you'll see, PBASIC 2.5 makes writing the IF-THEN clauses a whole lot cleaner, and will probably make following program logic a bit easier.
Jon Williams
Jon Williams
~Jeremy
~Jeremy
Jon Williams
