Random number
Hi out there, I'm trying to make a radom number generator with five outputs,· this is to blink lights in a radom matter, being new at this, would beg for some help.
Thank you
Old redneck hillbilly born and raised on a redwood stump
Thank you
Jon Williams
Bill Horn
Crescent City
bill.horn@charter.net
Jon Williams
here is the old code, would like it for BS1.
port = &H378
RANDOMIZE TIMER
ct = 0
DO UNTIL ct = 5
FOR CR = 1 TO 31
r = INT(31 * RND + 1)
FOR I = 1 TO C * 2.5 'DELAY
NEXT I
LOCATE 6, 30: PRINT "TWENTY ONE "
LOCATE 8, 30: PRINT "RANDON ALL "
IF r = 1 THEN
OUT port, 1
ELSEIF r = 2 THEN
OUT port, 2
ELSEIF r = 3 THEN
OUT port, 3
ELSEIF r = 4 THEN
OUT port, 4
ELSEIF r = 5 THEN
OUT port, 5
ELSEIF r = 6 THEN
OUT port, 6
ELSEIF r = 7 THEN
OUT port, 7
ELSEIF r = 8 THEN
OUT port, 8
ELSEIF r = 9 THEN
OUT port, 9
ELSEIF r = 10 THEN
OUT port, 10
ELSEIF r = 11 THEN
OUT port, 11
ELSEIF r = 12 THEN
OUT port, 12
ELSEIF r = 13 THEN
OUT port, 13
ELSEIF r = 14 THEN
OUT port, 13
ELSEIF r = 15 THEN
OUT port, 15
ELSEIF r = 16 THEN
OUT port, 16
ELSEIF r = 17 THEN
OUT port, 17
ELSEIF r = 18 THEN
OUT port, 18
ELSEIF r = 19 THEN
OUT port, 19
ELSEIF r = 20 THEN
OUT port, 20
ELSEIF r = 21 THEN
OUT port, 21
ELSEIF r = 22 THEN
OUT port, 22
ELSEIF r = 23 THEN
OUT port, 23
ELSEIF r = 24 THEN
OUT port, 34
ELSEIF r = 25 THEN
OUT port, 25
ELSEIF r = 26 THEN
OUT port, 26
ELSEIF r = 27 THEN
OUT port, 27
ELSEIF r = 28 THEN
OUT port, 28
ELSEIF r = 29 THEN
OUT port, 29
ELSEIF r = 30 THEN
OUT port, 30
ELSEIF r = 31 THEN
OUT port, 31
END IF
NEXT CR
ct = ct + 1
LOOP
For those wondering why RANDOM is tossed three times ... we found this gives a more visually-interesting display when used in this kind of program.· RANDOM uses an LFSR (linear feedback shift register) and the nature of that design causes us to "see" the shifting of bits through it when RANDOM is called just once.
Jon Williams
Again tks so much
· OUT port, r
... could have replaced all those IF-THEN constructs as you had already limited r to 1..31.
Jon Williams
