Serial SRAM for BS2e
Hi All,
I need a Serially interfaced SRAM.
Other requirements :
1 - 4K X 8· size
2 - I2C or SPI, etc. type of interface
3- Volatile SRAM· (I do not want Non-Volatle SRAM)
4- PDIP package (something small 8 pins or so)
Please provide vendor & part number.
1 - 4K X 8· size
· I've never seen an 8pin SRAM (I2C or otherwise.)· There are still SRAMs (parallel) out there and they could be interfaced with a serial-in to parallel-out shift register/s.
http://www.parallax.com/detail.asp?product_id=604-00020
http://www.parallax.com/detail.asp?product_id=602-00008
Post Edited (PJ Allen) : 10/12/2005 8:04:05 PM GMT
PJ, those are EEPROMs and therefore non-volatile (ok you've edited your post
·1+1=10
Post Edited (Paul Baker) : 10/12/2005 8:05:34 PM GMT
One additional requirement :
5 - Unlimited write cycles (this precludes EEPROM usage)
PS's :
PJ : thanks for the response but I cannot use EEPROMS
Paul : #3 is important because of cost. Battery in NVSRAM will raise costs.
www.ramtron.comdoc/Products/serial.asp
There unfortunatley isnt a 4kx8 size (8kx8 is availible). Also another issue is they have discontinued the PDIP package, for prototyping purposes you can get a breakout board for 8-SOIC (like at www.sparkfun.com), then for production it will be cheaper in PCB real-estate because it takes up less space.
www.newarkinone.com sells 8kx8 SPI and I2C types for just over $3 apeice.
The parts you would be interested in are FM25640·for SPI and FM24C64·for I2C
·1+1=10
Post Edited (Paul Baker) : 10/12/2005 10:48:37 PM GMT
Thank you all for taking the time to post.
Mr. Baker - thanks for the FRAM recommendations + links. I will use this device for my project.
Richard
