servos not working
I'm using "What's a Microcontroller" version 1.9 and Chapter 3 is about hooking up servos to the breadboard.· Many of the servos aren't working.· I am running the servos with batteries because I don't have a 9v wall transformer and I remember reading the batts get used up quickly.· Could this be the problem?· Some breadboards will work when I try a new servo but other breadboards won't work with any servo.· I've checked the setup and everything.
Any suggestions?
Thanks!
Alicat
Any suggestions?
Thanks!
Alicat
·· Have you tried a fresh battery, just to make sure?· 9V batteries have very low current capability and run our very quickly when using servos, which draw a lot of current.· Which board are you using?· Is it the Homework Board?
csavage@parallax.com
