can I power a BOE bs2 with a 12volt car battery?
I wanted to have my stamp run off of a 12 volt car battery. I thought I read somewhere that a bs2 could be powered by a range from 5 to 15 volts. But my BOE says 6-9 volts on the power plugin. What would be the best way to run this board from a 12 volt power source?
thanks
chad
thanks
chad
Jon Williams
The power would be from the battery only (not while in the car). Can I just plug the 12 volts into the regular 6-9 volt plugin?
What is the max it can take? I was thinking maybe at some point of hooking a solar panel up to the 12 volt battery to keep it charged. The solar battery chargers I have seen put out about 14-15 volts. At what point would I need to think about worrying about frying the stamp?
thanks
chad
Jon Williams
73
spence
k4kep
