IR Laser Question
IF using an Infrared Laser diode (980 nm) with the Freqout instruction, would it detect on the Infrared receiver?
"implying that interfacing with the 3v diode driver circuit."
Or is this one of those Trial and error type of questions....
thanks for any help.
Gary D.
Always Remember to use Proper eye
Protection When Using Lasers !!
Gary D.
That would depend upon which IR receiver you are using. If the receiver is a simple photodiode/phototransistor that is sensitive at 980 nm (check the spec sheet), then yes. If you are using a receiver module that expects a modulated carrier frequency (typically 38 kHz, but there are a variety of them out there- check the spec sheet), then no- unless you are running the laser diode at the appropriate carrier frequency also. To know for sure we need a bit more info about your set up, and what you are trying to do.
peter
Peter C. Charles
Director, Research and Technology
CyberBiota, Incorporated
Peter.charles@cyberbiota.com
http://www.cyberbiota.com
·(I like feedback when I post them in the Projects section)
In General:
i am working on a serial comunication system, IR Leds are not long range and spread light over distances.
The IR Laser diode and driver·allow the Laser to act like an standard led. when you apply 3v the laser turns on.
so i am assuming using the Freqout command (38 Khz) just as you·would an IR led·the IR detector would detect
the signal. does anyone know the Wavelength·of the IR emmiter sold in the parallax store?
I would just like to know if it is capable before buying the $50 IR laser.
Gary D.
The IR emitters wavelength is typically around 940-980nm.
Now thats Insane Engineering !!
GaryD.
There are 10 kinds of people....
Those who know binary and those who Don't.
·· Insane are the kits you can buy which aim a laser at a window and receive the modulated reflection allowing you to effectively "listen in" to conversations from who knows how far away.· So modulating a Laser isn't uncommon, just needs to be adapted to a constructive use.·
csavage@parallax.com
take a BS2, 5 IR detectors, a 30mW 980nm IR laser, a visible 650nm 10mW RED laser, IR serial Decoder, couple of High Bright Leds, and a vibrating motor.
now if you happen to multiply everything above by two, then you will have one awesome laser tag system. Oh yeah i forgot to mention, mount everything in an airsoft Mp5 submachine gun... and you have tactical laser tag.
now let your imagintion work on that...
Total system per gun $250
of course my system will have LCD screens built into each gun.
