Serial Communication
I have toyed around with boebot's for a couple years now.· My senior project is to control my boebot via a C# application I wrote from a remote laptop.· Does anybody have any tips for me.· I know the bot won't do anything with the serial cable plugged in, so how can I send it commands?· Is this even possible?
Any help would be greatly appreciated,
Tom
Tom
Jon Williams
We used the EB500 bluetooth module for the hydrogen fuel cell robot. We wrote an app in VB for the PC side, and it works great. We can control all aspects of the robot, monitor the fuel cell, etc. The EB500 takes care of CRC, allows easy flow control and in general has been teriffic. Range is good and if your laptop/PC doesn't have bluetooth, a $29 dongle takes care of that.
You can check out 'bot out at: http://madlabs.info/H2_FCRobot_Chron.shtml
HTH,
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
I'm not familiar with the boe-bot but here is what you need to do the EB500.
Look up the EB500 and find out what pins it requires from the Stamp, and make sure that those pins are free.
Check and see if the PC you are going to use has Bluetooth. If not, purchase a dongle. We use the Linksys USBBT100. Install drivers.
The EB500 docs have code examples to get you started. We initially used Hyperterminal to communicate with the 'bot. While that has limitations, it is easy and quite effective.
Then work on your C++ app.
HTH,
Jonathan
Yes you can develop a soft in C# that talks serially to your bot and send it commands.
The only problem is the lenght of the cable...the boe-bot wont go far......
This is why some here suggest you should get (not in the standart boe-bot kit) a bluetooth link (the EB500 for the boet-bot while an USB adapter will be fine for your PC) or, as Jon Williams says (always listen to Jon [noparse];)[/noparse] ), just buy two RF serial modem. The idea is the same : use radio link between your bot and your PC.
Here's my own trick : I did exactly the same thing.
But i'm the lucky owner of a WIFI Ipaq that also have serial connection. So I did a soft (in C#) for the PocketPC to be a TCP/UDP to SERIAL proxy (some kind of server) and a client software for the PC. When the PC sends a command thru WIFI to the PocketPC, the Ipaq relays the command to the Bot...
I may have the code if you're interrested.
Good Luck !
