Need help with Javalin to E-Mic code ... Writing Strings of data into eeProm.
Attention: Peter, Ryan or anyone !
//Our objective is to send text strings and command codes from the Javelin to the E-Mic Speech Chip.
// Our code is downloading with no syntax errors and the E-Mic chip is being reset correctly due to-
// the soft_Reset method that we are calling.
// Note: our main method also calls methods to receive serial data which is also working correctly.
// We understand that the while statement in the main method will change at a later date.
//We need to fully understand how to load text strings or equivalent values into EEPROM, then send them out to the-
// E-Mic chip along with command codes.
import stamp.core.*;
public class Main_Receiver{
final static int dataPin = CPU.pin4;
static Uart rxUart = new Uart ( Uart.dirReceive, dataPin, Uart.dontInvert, Uart.speed2400, Uart.stop1 );
static StringBuffer buffer = new StringBuffer(128);
static char SpeechCode;
//__________________________________________________________________
final static int Tx = CPU.pin0;
final static int Rx = CPU.pin1;
final static int Busy = CPU.pin2;
final static int Rst = CPU.pin3;
final static int Aout = CPU.pin7;
final static int baud = 396;
final static int TmAdj = 100;
final static int FrAdj = 100;
// final static int char;
final static int eePntr = 0x00;
final static int EOM = 0xAA;
// final static int Say = 0x00;
final static int Volume = 0x01;
final static int Speed = 0x02;
final static int Pitch = 0x03;
final static int Reset = 0x08;
final static boolean buttonOn = false;
final static boolean buttonOff = true;
//_________________________________________________________________________
static void bufferMessage(){
SpeechCode = 0xff;
//treat \r as newline
while (SpeechCode != '\n'){
if (rxUart.byteAvailable()){
SpeechCode = (char)rxUart.receiveByte();
if (SpeechCode == '\r') SpeechCode = '\n';
buffer.append(SpeechCode);
System.out.println((char)SpeechCode); //display incoming message
static void soft_Reset(){
CPU.writePin(CPU.pin3, false);
CPU.delay(10);
CPU.writePin(CPU.pin3, true);
static void Init(){
CPU.shiftOut(CPU.pin0, baud, 8, CPU.PRE_CLOCK_MSB, 0x01); //Command to set volume
CPU.shiftOut(CPU.pin0, baud, 8, CPU.PRE_CLOCK_MSB, 0x06); //Volume set at 06
Check_Busy();
CPU.shiftOut(CPU.pin0, baud, 8, CPU.PRE_CLOCK_MSB, 0x02); //Command to set speed
CPU.shiftOut(CPU.pin0, baud, 8, CPU.PRE_CLOCK_MSB, 0x02); //Speed set at 02
Check_Busy();
CPU.shiftOut(CPU.pin0, baud, 8, CPU.PRE_CLOCK_MSB, 0x03); //Command to set pitch
CPU.shiftOut(CPU.pin0, baud, 8, CPU.PRE_CLOCK_MSB, 0x03); //Pitch set at 03
Check_Busy();
static void setEEProm(int n){ //have to chop n into bytes
EEPROM.write(0,(byte)(n&0xFE));
EEPROM.write(1,(byte)(n>>8));
static int getEEPROM(){
int x;
x=EEPROM.read(1);
x=(x<<8)+EEPROM.read(0);
return x;
static void Check_Busy(){
CPU.delay(1000);
// While(CPU.readPin(CPU.pin2));
public static void main(){
soft_Reset();
Init();
Check_Busy();
setEEProm(0x42); //this just loads the EEPROM with the decimal equivalent 65, which we want to be the ASCII "A"
System.out.println("Bytes available in EEPROM:");
System.out.println(EEPROM.size());
System.out.println("The value you wrote to EEPROM:");
System.out.println(getEEPROM());
CPU.delay(1000);
CPU.shiftOut(CPU.pin0, baud, 8, CPU.PRE_CLOCK_MSB, 0x00); //0x00 is a command for the E-Mic chip to Say( English text)
CPU.shiftOut(CPU.pin0, baud, 8, CPU.PRE_CLOCK_MSB, 0x42); //Here we are trying to have the speech chip "say" the letter "A"
while (true) { //receive and display ALL messages
buffer.clear(); //clear buffer
bufferMessage(); //receive and display one incoming message
SpeechCode = 0xff;
CPU.delay(10);
static void Init(){
Check_Busy();
Check_Busy();
Check_Busy();
int x;
x=EEPROM.read(1);
return x;
CPU.delay(1000);
soft_Reset();
Init();
Check_Busy();
CPU.delay(1000);
The same eeprom the javelin code is stored in, or an external (I2C) eeprom?
If it is the javelin eeprom, you can use
EEPROM.write(addr,bytevalue) to store a byte· - start writing at addr 0
bytevalue = EEPROM.read(addr) to read a byte
The maximum number of bytes you can write is given by
int freeEepromSize = EEPROM.size();
You can also just define static final Strings or char arrays like
static char[noparse]/noparse cmd1 = new char[noparse]/noparse{0x01,'R','E','S','E','T',0}; //command 1: RESET (example)
Then use a loop to send the command
int index= 0;
while (cmd1[noparse][[/noparse]index]!=0) tx.sendByte(cmd1[noparse][[/noparse]index++]); //send all bytes from cmd1 array
regards peter
·We are using the eeProm in the Javalin ....
Thanks again ...
JMLStamp2p
we have this line right below our constants and variables. // is this right?
while (cmd1[noparse][[/noparse]index]!=0) Tx.sendByte(cmd1[noparse][[/noparse]index++]); //send all bytes from cmd1 array
we are getting the following error with the "Tx"....
...Error: The type of this expression, "int", is not a valid reference type in this context.
We also would like to know if there is any other literature, besides the Manual, regarding the Javelin Stamp available ???
We are a lost ball in high weeds at the moment, but we are learning. Thank you for your time and
patience as usual.
·while () etc
must be inside a method (main or other function).
The char array definition must be outside any function (global definition)
regards peter
For example, the emic is a speech synthesizer, so it would make sense to
create a package stamp.peripheral.sound.speech.emic
You do that by entering the folder %path%/lib/stamp/peripheral
There you make a folder sound
In folder sound you make a folder speech
In folder speech you make a folder emic
Now create a new javelin file
package stamp.peripheral.sound.speech.emic;
public class Emic {
· //constructor
· //assuming interface is bidrectional uart
· private Uart tx;
· private Uart rx;
· public Emic(Uart tx, Uart rx) {
··· this.tx = tx;
··· this.rx = rx;
· public void reset() {
··· //reset code
· //other functions for the emic
In your main class file
import stamp.peripheral.sound.speech.emic.*;
static Uart emicTx = new Uart(Uart.dirTransmit...); //complete this
static Uart emicRx = new Uart(Uart.dirReceive...); //complete this
static Emic myEmic = new Emic(emicTx,emicRx); //define your emic
accessing your emic from your main application file now consists only
of calls like myEmic.reset() etc.
This way your main class file remains clean of details for peripheral interfaces.
It also allows you to add more Emic chips in seconds by just defining another Emic.
regards peter
