recording sound with Piezo speaker — Parallax Forums
japerjaper Posts: 105
edited 2005-10-11 02:14 in BASIC Stamp
hello
could i use a Piezoelectric speaker as a microphone to record frequency into basic stamp
would like to stay with the kit material of BAAD and What a Microcontroller
is this Possible.
i'll do the work just need to know if this is an option.
just looking to actually do it,not looking for high fidelity
thanks
    edited 2005-10-10 19:35
    It is possible to use a Piezo Speaker as a microphone pickup.· Frequency response will be limited, and sensitivity will be an issue.· You will definately need an Op-Amp such as the LM358.
    csavage@parallax.com
  • japerjaper Posts: 105
    edited 2005-10-10 20:25
    Thanks Chris,
    Just happen to have a 358 Op-Amp that came in the BAaD Course
    due to limitation of memory and Keeping true to the course,
    I am just looking to perform the task.
    Looks very Challanging and Am looking forward to it.
    Thanks again Chris
    japer
    edited 2005-10-10 23:04
    You probably won't be able to do more than detect sound.· What you will need to do is configure the op-amp as a comparator (Or as an amplifier) so that a small signal detected on the inverting input creates a larger change on the output.· You can use the non-inverting input as a reference voltage if you're using it as a comparator, or you can re-configure it for use as a signal amplifier.· There are plenty of references online for doing that.
    hello
    i was thinking of boosting the signal with an NPN and some caps maybe
    but the OP-Amp is a single source and proabaly the best space saving
    solution.It's defently an off the wall challange for the chapter
    But the deeper you get the deeper it gets
    thanks again
    japer
