7-Segment Display
Hello All,
I'm very new to Basic 2 and I got a question on maybe someone can answer me.
I need to display a 4 digits number using 7-segment LED. I like to know if is possible to do something like that?
If is possible how is it done?
Also what is the alternative method of doing something like that? Maybe using a crystal LED?
Borna
Post Edited By Moderator (Jon Williams (Parallax)) : 10/10/2005 4:32:05 AM GMT
Borna
Jon Williams
·· Might you want to do something like in the thread listed below?· If so there's plenty of schematics and code there.· There's also examples of using the same chip in the StampWorks guide, which can be downloaded from our website in PDF format.
http://forums.parallax.com/showthread.php?p=552892
csavage@parallax.com
when you said four different digits on one physcial display, are you talking about something like Serial LCD? If so is there some code example that I can review?
Also Chris, the link above is very interesting, I'm reviewing that now.
Borna
8
or like this:
8888
If the second, you really should use a display driver like the MAX7219 or MC14489 (less flexible, but cheaper).
Jon Williams
Thanks again
Borna
Jon Williams
Sid Weaver
Do you have a Stamp Tester yet?
Borna
