Interfacing a Stamp with a NON-Sony Infrared Controller
Group,
I need to be capable of decoding a infrared code from a remote that is proprietary.
The remote controls some medical equipment (nothing life risky). I'd like to be able to recieve the codes and retransmit them. I need to send the code back out an LED and into the computer.
My problem is figuring out how to capture the IR information. I know how to interface with the computer. What I don't know is how I would go about retransmitting it, and capturing it in the first place. I originally attempted to read the controller using the example code for the Sony remote, hoping that might work, it obviously didn't.
I'm willing to purchase a Stamp Logic Analyzer and a USB O-Scope from Parallax, if that will solve the problem. The usage is a critical thing. I purchased something from Smarthome to do the same stuff, and it was REALLY hard to interface, then it didn't work half the time. And the application that I have, I need it to work more reliable.
The IR transimission will be almost point blank, the recieving will be less than 30 feet, probably even less than 15 feet.
I am using a standard BS2, but if I need the speed I'm more than willing to upgrade to a BS2P.
My main question is finding out how to go about decoding this proprietary remote interface. I can tear apart the remote and find the IC number if that'd help. [noparse]:D[/noparse]
TIA,
Knight.
TIA,
Knight.
This way I never touched anything electrical with the medical device, and I won't have to worry about the warranty not being good.
I say "medical device" like it's a big secret, I just didn't think anyone cares what it is, but it's a phorotor. Or, Refractor. They are the things that the eye doctors put in front of your face and move the lenses around, then get your prescription from. Only this one is controlled 100% with IR. And I need to integrate that refractor into my VB program.
I'm just wondering if the Logic Analyzer can allow me to decipher the codes for the remote, in the way I mentioned above?
Knight.
The H8/3664 in google turned it up as being a microcontroller. So this means it's not just a normal IR asic, it's a MCU. So, I can't just look up it's protocol. [noparse]:([/noparse]
The IR LED looks pretty standard, so on second thought, hookin up a O-Scope to the LED's leads, might not be a bad idea...... It would eliminate the possibilty of the inaccuracys in timing on watching the actuall output from going through IR itself.....
Knight.
You may want to take a look at this I/R Analyzer for less than $100.00 US:
http://www.mpja.com/directview.asp?product=8837+RB
Bruce Bates
Bruce,
Looks interesting. But I would think that's it esecially similiar to the Stamp Logic Analyzer, with a IR detector on it. Right?
I'd rather get a stamp logic analyzer, that way I can use it for the staps too....... Unless you can see some other difference to this IR analyzer that might make it werth the additional purchase. [noparse]:)[/noparse]
I do appreciate the help though!
I think what my main question outta be is, can the Stamp Logic Analyzer be used to determine the IR information from a non-sony remote?....
Knight.
The SSIR is nice, because it has an IR transmitting LED as well as the reciever in a nice, small, easily interfaced package.
So, you connect this thing up, attach your logic analyzer, and aim your 'mystery device' remote at it. The logic analyzer should show you the stream of bits that the device sends.
Now, generating that stream with a BS2 can be a problem. If you use a 555 timer to generate the 38 Khz signal, you can 'modulate' that signal using "PULSOUT" to generate your bits.· But at least this gives you a place to start.
·· The SSIR is currently discontinued, so it can't be ordered right now.· I don't have a projected date on a return.
csavage@parallax.com
·· This is true, I just wanted to save someone calling in to order one and finding we don't have any.·
a bs2p may do the job bs2 is a bit slow and maybe 16 or so pulsin commands
a scope would be nice but you can get by without
the 16 pulsin commands will read the value of 16 pulses if your remote only uses 8 then fine you will only need
8 commands ( it could use more )
save the values of each pulsin and display using debug the value of pulsins will look like 288 150 150 288
that would be something like 1001 or 0110 it really doesn't matter how you read it there is usually a start bit
which is longer (ex. 400) so you just loop until you read a 400 then go on to the rest of the pulsin commands
but to start you will just read all the pulsin commands just to get the timing correct and look for common
factors· like example above 288 150 150 288 this will tell you the differance between low and high. all the
numbers are examples not correct values just what may be streaming out of your remote.
this should get you started.
Gladly. I don't know how much help my experiences will be to you, since I'm using a Nidek Phorotor, but I'm going to be releaseing everything I find on the net. [noparse]:)[/noparse]
Knight.
Thanx! I have the following already:
http://www.parallax.com/detail.asp?product_id=350-00018
http://www.parallax.com/detail.asp?product_id=350-00014
So, I think with these two, I should be able to do it. I did like the idea of it all being in one compact unit! But oh well, two separate components is fine.
Just to clarify, the IR LED listed above is called a "IR Transistor", is there any difference in operation or even in connections to a normal LED? IE, if I'm using a 5v+ source, using a 470OHm Resistor should be fine as a current resistor, and nothing else needed?
I ordered a Logic Analyzer, and a BS2 (All of my Basic Stamps are integrated, and I only purchase the PIC's themselves from Parallax, so I never had a true, "Stamp", just a "basic". [noparse]:D[/noparse]), via 2nd day air, so hopefully will get it Wednesday, so we'll see what I can do on Wednesday. I have tried to get the info without a scope, and I don't think there's anyway I can do it. Once I get the data, I'll try to figure things out on my own....however, I've NEVER had ANY success with IR in the past! I HATE IR. I can do all kinds of stuff, but NOT IR! lmao. I don't know why, but it NEVER works for me. (Except normal ALL for one remotes that I programed with the original remote) I've tried doing SIMPLE IR stuff, like detecting a beam, doesn't werk....
TIA,
Knight.
