DMX dimmer with an SX chip?
Has anyone ever made a DMX light dimmer with a Stamp? I've seen some work on Stamp DMX controllers but nothing on dimmers (the thing that receives the control information and actually turns the lights on and off). According to the research I've done the DMX baud rate is too high for a BS2 but should be possible with the SX.
Thanks!
Thanks!
http://www.euro-pa.be/dmx.html
Looks like you need http://focus.ti.com/docs/prod/folders/print/sn75176b.html
to take of the high speed data transmission.
Think outside the BOX!
csavage@parallax.com
The speed of DMX is 250 kHz, not 384 kHz. With the SX running at 50 MHz, you can execute 200 instructions between each bit coming in. As you say, it's definitely do-able.
PeterM
http://forums.parallax.com/forums/default.aspx?f=25&m=132052
I had asked the question if one could use an SN75176 chip, an MCU and a Quadrac as a DMX slave unit. It will be interesting to see if it could work.
John J. Couture
San Diego Miramar College
To answer your question, I'm pretty sure that the way the RS485 protocol works is that it just checks the voltage difference between the two wires and each end has its own power supply and its own ground reference. This is why RS485 works for such great distances (at least that is the way I understand it ... not that it is right
The RS485 chips (SN75176) are cheap (i.e. Jameco $0.23 USD each) and you need one on each end. You can run a signal over twisted pair for a couple thousand feet in the kHz range. I have a few that I play around with and they are well explained in Jan Axelson's book "Serial Port Complete" (ISBN 0965081923 )
Quadracs (about $1.20 USD) are a little more difficult to find information on. You see references to Triacs and SCR's but Quadracs aren't used in a lot of hobby projects that I've been able to find. They are a three pin TO-220 devices that can be, in theory, used as a variable motor controller. I've yet to get them to work with my surplus TLP630 (Darlington Optocoupler) to get a true ON/OFF for 120V fan motor with optical isolation. My ultimate goal is to try and build an inexpensive speed control for a ceiling fan that doesn't make noise (cheap ceiling fans, the kind I buy, are generally noisy at lower speeds .... tough to sleep under).
Anyway, here are some reference materials if you are interested.
Datasheets
SN75176 (RS485 Transciever)
http://focus.ti.com/lit/ds/symlink/sn75176b.pdf
TLP 630 (DIP8 Darlington Optocoupler)
http://rocky.digikey.com/WebLib/Toshiba/Web Data/TLP630.pdf
Quadrac (A souped up Triac)
http://www.jameco.com/wcsstore/Jameco/Products/ProdDS/160240.pdf
John J. Couture
The minus line does exactly the oppostie of what the positive line does.
When the +signal is 5V volts, the -signal is 0V. When the +signal is 0Volts, the
-signal·is 5 volts.·The reciever looks·at the DIFFERENCE between the two
lines. The reason this is done, is that if you induce noise·on the wire between
your RS485 devices, both the +signal and -signal·get the same noisevoltage,
and the difference remains the same (This is key to noise immunity)
Since the reciever·looks at the difference only, the·noise is ignored.
This is what gives RS485 immunity to noise that RS232 doesn't have.
Note that you are talking about RS485. There is also an RS422 specification.
The·RS485 and RS422 use the same signaling (Voltage levels). However, One
is specified as unidirectional, and the other is bidirectional. RS422 has a TX pair
and RX pair of wires (5 wires total). On·RS485 line (3 wires total), data flows
in both directions on the same wire. In reality it is a little more complex
than that...· ...but this should give you the·rough idea.
Check out: http://www.national.com/an/AN/AN-216.pdf
National semiconductor also has some more info on the subject, but you will
have to search for it...
Hope this helps.
-Dan
"A saint-like quantity of patience is a help, if this is unavailable, a salty vocabulary works nearly as well." - A. S. Weaver
PeterM
