Where exactly can I see others' Java code for the Javelin?
After some deliberation, I finally decided to order the Javelin stamp (and accessories). I was planning out some classes I would write, but I wondered if anyone else has already written this same class.
I looked at the post on about the Yahoo group, but I couldn't find much there. I also looked at the classes posted on Parallax's database, but they seem very general and formal. Is there anywhere where anyone can simply post their code? I found one Javelin project that had some code posted in the "projects" forum, but thats it. Any help would be appreciated. Thanks.
Post Edited (bulkhead) : 10/7/2005 2:58:39 AM GMT
installed with the javelin IDE. They are located in the same subfolder(s) as·with the IDE
(which is·$path$/lib/stamp)
http://groups.yahoo.com/group/JavelinCode/files/Javelin%20Stamp%20IDE/lib/stamp/
You may also post your classes there. Pleasy apply to the folder use. That way classes
are easiest located.
regards peter
