bs2 voltage regulator app
i need to write an application that i can regulate voltage to a fan so i can controll the fan speed and also regulate voltage to an heat line. im kinda new to this so be nice [noparse]:)[/noparse]
its all to an microsupport product to an project in school. any help would be appreciated.
Niclas
Niclas
·· Do you have any idea how you want to go about this?· It sounds like a DAC might be what you'll need.· Possibly more than one from your message.
csavage@parallax.com
·1+1=10
Chris do you know if driving a DC motor with a variable voltage would provide less torque in the motor than the PWM? I know that most motors require a minimum startup voltage to get it started, does providing the motor with an equivalent PWM duty cycle suffer the same problem, or does the impulse voltage within the PWM train overcome this issue?
·1+1=10
·· I believe PWM drive provides more power to the motor (In the form of torque) than adjusting the voltage, and as I admitted, has the additional benefit of·providing more control over a wider range, which would explain why most motor controllers utilize PWM for the control system.· There is no question it is the better way to go.· Simpler would be varying the voltage, depending on how you look at it, but I don't have the details so I can't say what the OP should use.· He will have to base that on our information provided.
·1+1=10
