Where to start
I recieved mi order today but i'm not sure where to start.
This are the parts that i have, a BOE USB, BS2 IC and a continuous rotating servo.
What i want to do is write a sequence for the servo, load it in the BS2 and run it.
Where do i start?
Thx
Where do i start?
Thx
Now i can controll servos and use leds for debuging, i even got the ping sensor to work, all in a few hours.
Tomorow i want to conect it to the rc car that i have but have a question about it.
The power that i use for the boe is 6Volt, the power to drive the rc car is 12Volt.
The steering servo is conected to the reciever, the motor is conected to some sort of controler wich is then conected to the reciever.
Can i conect the conections that go in the reciever to the servo controles of the boe without damaging anything?
The connections the Stamp needs will require that you cut all motor and servo leads and reroute them to the Stamp.
