SASM Error
In version 3.10 of sx/key, when using SASM, I get the error window "file not found"
"drive/path" not found on disk on all attempts to assemble.· I do not have the problem when I use the original Parallax assembler.
Any suggestions on how I should setup so this will work properly with SASM.dll
Can you give some more detail about what you're doing, etc?
1 - Did you do a normal install of the IDE, or did you customize it somehow?
2 - Does your code have more than one source file?
3 - Can you post the exact error message?
4 - Have you used an earlier version of the IDe and had it work before?
5 - Has 3.1 and SASM ever worked for you before?
Thanks, PeterM
