360 degrees around a pole
Ok, I don't even know how to search for this (and I tried, but I'm using the wrong keywords or something). And I've only completed one parallax project, so I'm kinda of a newbie.
What I'm basically trying to do is have a wheel go 360 degrees (around and around) around a pole, and have the parallax tell me what degree in the rotation around the pole I'm at (from 0 to 360). (this is really a wheel and a real pole - not virtual)
Could someone tell me how or point me in the right direction?
Darryl
Darryl
Steve
Punch slots in the edge of the wheel and use a few IR collectors to read the rotation.
the 1,2 and 3 are collectors as the slot moves over them tey give a logic low on pin 1, then pin 2 then pin 3 going one way . In reverse they would read 3, 2 , 1 so with a bit of programming and cutting 120 slots. Logic would be poll all pins for a logic low, wait for the next pin to go low,
i
Logic truth table
Pin1=low, next pin to go low is 2, wheel has moved clockwise 1 degree
pin1=low, next pin to go low is 3, wheel has moved counter clockwise 1 degree
pin2=low, next pin to go low is 3, ehrrl has moved clockwise 1 degree
etc.....
2 Slots with three collectors shown the "||||" is the section that blocks the light from the collectors that gives the signal.
1 2 3 ||||
At one point all three are high, and your logic is waiting for the first pin to show a low, in that case the first pin to go low shows the direction 1=clockwise and 3=counterclockwise.
Hey this is pretty cool I just thought it up while I was responding to this post. I may have to use it for something.
Its a type of encoder used for position control.
Here's a place to start- http://www.mcmanis.com/chuck/robotics/projects/encoders/enc_gray.htm
I suppose there are dozens of ways to accomplish what you're trying to do, finding where you are radially, relative to one central location. For my money the cheapest, easiest, and fastest way to do it is to use an electronic·compass, similar to that's offered by Parallax here:
··· http://www.parallax.com/detail.asp?product_id=29123
Here is the short and sweet version of the proposed program. Once the program is started, during the program initialization phase, you field the present heading from the electronic compass, and store that initial or starting position. Presently this is your "true" heading, but this will later become your "offset" to calculate relative position. Once you take the first "official" reading (past initialization), you take that new heading, compare it in magnitude·to the stored heading, subtract the smaller from the larger, and you now have your relative position around the pole. Continue that same process as often as may be necessary. What could be simpler?
I suspect the electronic compass documentation, which can be found at the location above, will address the·issues of accuracy and resolution, if that's important to you. In less than 20 minutes and about $30.00 US you should be good to go! Just be·remember to mount the electronic compass as far away as you can from anything containing ferrous metal, and anything with magnetic coils.
Bruce Bates
You could use a hall affect sensor and put magnets on it at certain intervals and count them.....bah, to be honest...a $5 pot and $5 gear (or some way to attach the pot to the shaft/wheel) would probably be just as easy (knock on wood).
There's some real easy/basic ways to do this...then there are more creative ways to do this as well!
You could mount a laser to the wheel and have it pointing straight up/out and then have a whole bunch of phototransistors in it's arc/path.
A pot or encoder would be the way to go....unless you have lots of these other surplus items kicking about!
Steve
Sid
