Help with CMUCam
Hi everybody,
I'm an electronics hobbyist and i'm new to Robotics. I bought the boe bot kit from radio shack last week and i enjoyed alot of cool projects with it. I have also another basic stamp board of education and i made it to communicate with boe bot through an IR.
I bought a camCmu from jameco and I'm trying now to implement it with the boe bot, but i don't know how...
I need some help with what should i do so my boe bot can use the Cmu to avoid and identify objects...
I also wanted to build an ultra sonic sensor without having to buy it. i bought also the Tranciever and Reciever SENSOR,ULTRASONIC,40KHZ. I will appreciate ur guys help.
thank u
Post Edited By Moderator (Chris Savage (Parallax)) : 10/4/2005 11:28:11 PM GMT
thank u
http://www.parallax.com/detail.asp?product_id=30051 this is on their product page for the CMUcam!
Google is your friend!
Also, take things one step at a time!
Play with the ultrasonic sensor and see if you get any readings back....then play with how to incorporate those readings in to lighting an LED at certain ranges or turning on a servo! Don't try to do everything at once!! You'll just get lost! (at least I would!)
Steve
but i need to build the ultrasonic sensor first
i don't have the Ping)) sensor..
i only have ULTRASONIC,40KHZ tranciever and reciever.
i tried to hook them up on the basic stamp board with a resistor and i tried to freqout command
to flash a led when an object pass in front of the sensors.. but nothing happened.
i know for sure the code is right. but something is wrong in my circuit
i read something a bout using the 555 timer ... if u have some schematics for the sensor that will help..
PS this was found using "ultrasonic 555 distance schematic" in Yahoo (sans quotation marks).
·1+1=10
csavage@parallax.com
Now i can build and try the ultra sonic sensor.
What about the CMUcam that i bought without the extra parallax board to employ it with the stamp??
any ideas??
