Expresspcb.com PCB design and construction
I'm a· newbie that is looking for software to document circuits I'm breadboarding and potentially to have them constructed.·· I was wondering if anyone here had suggestions re: preferred software to document your circuits and further if anyone had had experience with Expresspcb.com I've seen advertised in Nuts & Volts.
Hopefully this is not off topic .. I am using this for Stamp projects.
Sid Weaver
Do you have a Stamp Tester yet?
Jon Williams
ExpressPCB's software is really easy to understand, and offers really basic stuff. However, if you design anything in their software, you CAN'T move it to any other software, and you MUST use THEIR production facilities. They really limit what you can do with this "free" software.
I used to use it, however I have recently switched to Eagle. (http://www.cadsoft.de/) I would recomend it, as it's very flexible. It also has much higher end features. Something that is really neat is the AutoRouter. You create the schematic, then put all the components where you want them on the board, and click Autoroute, and it'll automatically route all the traces. ExpressPCB doesn't offer anything like this.
I'd suggest playing around with ExpressPCB, but don't get too attached, then make the move to Eagle. If I started out on Eagle, I would have been completly lost, so the ExpressPCB was a good starter.
Just my $0.02.
Knight.
ALot of them use what's called "gerber" files....and Eagle can export Gerber files.
Knight.
I would learn both software programs to give you a wider spectrum of options. ExpressPCB would be a good choice for small simple circuits and Eagle could be used for your more advanced circuits. Its good to be proficient on a variety of software platforms and then you can simply pick your flavors to best suit your needs.
Formally RoboROOKIE.
I make my prototype pcb's using the Pulsar-based toner transfer system using ExpressPCB software. Its a cheap, easy system for hobby users.
