Horay for the Basic Stamp it did not blow up!
Playing around with the darlington ULN2803 and an old floppy stepper running at 5 volts The stepper is rated as 12 so I decided to put 12 volts to it. Hmmm I said thats funny the green light glows brighter on the stamp when I hook this up. Yikes I forgot to disconnect the +5 rail to the darlington when I pushed 12 volts back at it.
It shut down, I felt a bead of sweat on my forehead but then unplugged the battery and replugged it in and all seems well. Whew
Now I know steppers should run at at least 2x the rated voltage and you can use resistors to reduce the current.
I measure 85 ohms of resistance between the common and one of the coils (170 per coil) (5 wire stepper MSJE200A53 No. 1Y21)
If I double the voltage to 24 volts should I use 85 ohms power resistor in series
can you use PWM at a 50% duty cycle and create a chopper drive but perhaps the darlington is not fast enough switching?
Thought I should ask before I make smoke
It shut down, I felt a bead of sweat on my forehead but then unplugged the battery and replugged it in and all seems well. WhewNow I know steppers should run at at least 2x the rated voltage and you can use resistors to reduce the current.
If the stepper has a rated current, then what you want to do is connect your supply and adjust the resistor value to get that amount of current. The "chopper" circuit is much more effecient, but more complecated because it is actually a current regulator (you need feedback from the circuit).
The reason for all this is that the coil of the stepper has a large inductance. And inductance resists change in voltage. So when you first apply power to the coil the current is low (so too the magnetic force), then increases as the coil saturates. The resistor is a crude attempt at current regulation that can waste many times the power supplied to the motor (but sometimes that's not a problem). The chopper is basically "full-on" initially then starts chopping the power as the coil saturates (and the current increases).
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
Available now... SX-Video OSD module $59.95 www.sxvm.com
"I'm a man, but I can change, if I have to, I guess"
Red Green
