No BASIC Stamp Found
I tried several times to download the program codes from the Stamp Editor v2.0/v2.2 to the SumoBot via a serial port but its always gives the error message 'No Basic Stamp Found'. May i have some assistances/suggestions on this error? Thanks!
Post Edited By Moderator (Chris Savage (Parallax)) : 10/4/2005 5:24:34 AM GMT
Are you using a custom cable? if so, check your wiring...
Rafael
·· Here are some things you can try:
1) Replace the batteries with a new set (No rechargeable)
2) If you're using a serial port connection try disabling the FIFO buffers
3) If you're using a USB connection or adapter try lowering the latency setting
BTW, I gave your post a more descriptive subject to make it more understandable.
csavage@parallax.com
You could try COM2 if you have one and replace the '{$PORT COM1} with '{$PORT COM2} if you suspect your COM1 is not working.
