SRF04 sonar code problems
I'm new to programing and the basic stamp. I'm still at a cut paste and modify stage in learning to program. My SRF04 works fine but the pause comands in my code cause the boe-bot to stop and start quickly. Right now my goal is to just have my to IR senors guide the boe-bot which works fine. Once adding the code for the SRF04 to report to the computer it starts the start and stop. Any sugestions on how to read from the sonar at the same time as running the IR code.
' IR object detection ultrasonic assisted navigation
' {$STAMP BS2}
' {$PBASIC 2.5}
DEBUG "Program Running!"
· Trigger···· CON 8
· Echo······· CON 9
· MoveTo····· CON 2
' Variables
· pulseLeft·· VAR Word
· pulseRight· VAR Word
· pWidth····· VAR Word··················· ' pulse width from sensor
· rawDist···· VAR Word··················· ' filtered measurment
· distance··· VAR Word··················· ' converted value
· temp······· VAR Word··················· ' value for RJ_print
· blips······ VAR Nib···················· ' loop counter for measurement
· digits····· VAR Nib
FREQOUT 4, 2000, 3000 ' Signal program start/reset.
' Initialization
Init:
· PAUSE 250
· DEBUG CLS
· DEBUG "Devantech SRF04 Demo", CR
· DEBUG "
", CR, CR
· DEBUG "Raw........... ", CR
· DEBUG "Inches........········ ", 34, CR
· DEBUG "Centimeters...········ cm", CR
' Main Program
Main:
DO
· GOSUB Get_Sonar······························ ' take sonar reading
··· DEBUG MoveTo, 15, 3
··· temp = rawDist
··· GOSUB RJ_Print······························· ' display raw value
· DEBUG MoveTo, 15, 4
··· distance = rawDist ** 8886··················· ' divide by 7.3746
··· temp = distance / 10
··· GOSUB RJ_Print······························· ' display inches
··· DEBUG ".", DEC1 distance
· DEBUG MoveTo, 15, 5
··· distance = rawDist ** 22572·················· ' divide by 2.9033
··· GOSUB RJ_Print······························· ' display centimeters
· PAUSE 200···································· ' delay between readings
IF (IN5 = 1) AND (IN7 = 1) THEN····· ' Decide how to navigate.
· GOSUB Backup
· ELSEIF (IN5 = 1) THEN
··· GOSUB Left_Turn
· ELSEIF (IN7 = 1) THEN
··· GOSUB Right_Turn
· ELSE
··· GOSUB Forward
· ENDIF
··· PULSOUT 13,pulseLeft ' Apply the pulse.
··· PULSOUT 12,pulseRight
··· PAUSE 15
· LOOP ' Repeat main routine
' Subroutines
Get_Sonar:
··· rawDist = 0·································· ' clear measurement
··· FOR blips = 1 TO 5··························· ' take five samples
····· PULSOUT Trigger, 10························ ' 10 uS trigger pulse
····· PULSIN Echo, 1, pWidth····················· ' measure distance to target
····· rawDist = rawDist + (pWidth / 5)··········· ' simple digital filter
····· PAUSE 10··································· ' minimum period between pulses
··· NEXT
··· RETURN
Backup:·········································· 'Backup
····· HIGH 10
····· HIGH 1
····· pulseLeft = 650
····· pulseRight = 850
··· RETURN
Left_Turn:······································· ' Turn Left
····· HIGH 10
····· pulseLeft = 850
··· RETURN
Right_Turn:······································ ' Turn Right
····· HIGH 1
····· pulseRight = 650
··· RETURN
Forward:········································· ' Forward
····· LOW 1
····· LOW 10
··· RETURN
RJ_Print:········································ ' right justify
····· digits = 5
····· LOOKDOWN temp, <[noparse][[/noparse]0,10,100,1000,65535], digits
····· DEBUG REP " "\(5 - digits), DEC temp
··· RETURN
' {$STAMP BS2}
' {$PBASIC 2.5}
· Trigger···· CON 8
· Echo······· CON 9
· MoveTo····· CON 2
' Variables
' Initialization
Init:
· PAUSE 250
· DEBUG CLS
· DEBUG "
", CR, CR
' Main Program
Main:
DO
··· temp = rawDist
· GOSUB Backup
··· GOSUB Left_Turn
· ELSE
··· GOSUB Forward
· ENDIF
··· PAUSE 15
' Subroutines
Get_Sonar:
··· NEXT
··· RETURN
····· HIGH 10
····· HIGH 1
··· RETURN
····· HIGH 10
··· RETURN
····· HIGH 1
··· RETURN
····· LOW 1
····· LOW 10
··· RETURN
····· digits = 5
··· RETURN
Since you're new I'll suggest you start by updating the servos before and after you read the sonar. Remove any unnecessary PAUSE instructions that are just part of the SRF04 demo. And then subtract a millisecond for every character you send via DEBUG from the PAUSE 20 instructions you would normally have between servo updates.
Jon Williams
' {$STAMP BS2}
' {$PBASIC 2.5}
· Trigger···· CON 0
· Echo······· CON 1
· MoveTo····· CON 2
' Variables
' Initialization
Init:
· DEBUG CLS
' Main Program
Main:
DO
··· PULSOUT 13, pulseLeft ' Apply the pulse.
··· PULSOUT 12, pulseRight
··· PAUSE 10
··· temp = rawDist
· GOSUB Backup
··· GOSUB Left_Turn
· ELSE
··· GOSUB Forward
· ENDIF
····· PULSOUT 13, pulseLeft ' Apply the pulse.
····· PULSOUT 12, pulseRight
··· PAUSE 10
· LOOP: ' Repeat main routine
' Subroutines
Get_Sonar:
··· NEXT
··· RETURN
····· HIGH 10
····· HIGH 2
··· RETURN
····· HIGH 10
··· RETURN
····· HIGH 2
··· RETURN
····· LOW 2
····· LOW 10
··· RETURN
····· digits = 5
··· RETURN
Do you see anywhere else I might smooth out the servo's? I would like to keep the distance reporting back to the computer.
csavage@parallax.com
