Parallax USB Oscilloscope Question
I'm considering buying one to help me with my home projects. Apart form the normal 0->5V stuff, I will also need to measure both RS232 and RS485 levels. Will I be able to do this either with the product as it ships, or will I need different probes. Are different probes available, the connector doesn't seem to be a BNC.
thanks,
Andy
thanks,
Andy
Sid Weaver
Do you have a Stamp Tester yet?
·· The USB Scope will handle 20V P-P from negative to positive side of the signal.· This boils down to a max 10V DC input down to -10V.· To go any higher you will need to build a divider.· Standard scope probes don't connect since our scope uses a barrel plug on the end instead of a BNC connector.
csavage@parallax.com
As I recall, the O'scope will measure 40 volts P-P.· There is no reference to frequency.· So why would the scope not measure -20 to +20 DC.
40 volts P-P is 28.28 RMS and the average voltage would be 0.· I have read +12VDC on my O'scope with no problem.
Sid
·· Can you post a screenshot of your scope reading 12V?
Sid
And will they work on a unit that old?
SN is OP81M1005020381 in case it's needed.
Thanks!
"Never create anything you can't control"
"The amount of intelligence on the planet is fixed... the population is growing"
·· The current version of the USB Scope software on our website should work fine with your scope.
Sid
thanks,
Andy
·· No linux version plans...I will see if I can get the engineer who designed the scope to answer your other questions tomorrow.
1- A resizeable main window, ultimately so that I could see the whole waveform
2 - seperate controls for each channel
3- A (much) longer waveform history. It would be nice be at a fine horizontal scale, but be able to go back several seconds in time. This goes hand in hand with #4
4 - once stopped, be able to change the horizontal range. The problem is capture the whole signal I have to be a quite a course horizontal range, but then it's much harder to decipher the bits. Zoom does not quite cut it.
5 When zoomed a grid, based on the horizonatal range and zoon factor.
6 A cursor control in the horizintal direction that is "click" based. That is one click moves X amount of time based on current horizontal division. Makes "Snap to Plot" much more useful.
To give you an idea of what I'm doing, I've been tracing issues related to I2c on my board. The oscilloscope works great for signal tracing and confirming that there is a signal, I set the trigger points and capture the I2c coms. I can see that I have data. To capture the packet though requires a course horizontal range. What I am now trying to do is read the data to make sure I'm sending what I think I am. That is proving much harder than it should.
It seems that the designers of the software really targeted lower end machines, which is great, but I have a P4 with lots of ram and a huge screen, it would be nice to able to use it if I have it [noparse]:)[/noparse]
thanks,
Andy
·· I will certinaly pass your information along to the engineer who designed the scope.· In the meantime I think you just found some reasons why our scope is more affordable and not closer to $300 or $400!·
·· The BASIC Stamp Logic Analyzer can not only capture several million samples of your I2C data, but it can even decode the data to show you what is being sent.· Please see our examples in the AppNotes on the product page for the BSLA.· I find the BSLA to be an invaluable tool to work with the Scope.· I find I use both quite frequently.
http://www.parallax.com/detail.asp?product_id=30010
