Using a relay on a WAM board?
I have been trying to use a Aromat DS2E-M-DC5V relay ( I have a bunch of them) on my three WAM boards using the 2n3904 NPN, a 4148 diode, and a 10K resister to the i/o pin 14.· It doesn't work.· If I power the relay directly from Vdd and Vss then it works but I can't get the stamp to operate it.
I would like to operate a number of halloween project windshield wiper motors (12v at 2A), ref/ scary terry site.
Any help would be most appreciated...I'm not a electrical engineer.·· If a different relay·must be used, is required instead·(one I can run over to Radioshack to get) let me know....
I have tried all of the WAM experiements and had no trouble running them and making all kinds of mod's but am surprised a relay was not included in the experiments.
·· The 10K resistor is too high to allow the transistor to bias.· Try a 1K instead.· Are you using the Homework Board or the Board Of Education?· Which revision?
csavage@parallax.com
Now for the possible bad news...If you're using Vdd for the supply, you should know that the regulator on the Homework Board Rev B probably doesn't have enough current output capability to run everything you're running.· You should consider running the power devices from a separate power source or Vin.· Or you can upgrade to a board with a beefier regulator on it, such as the Board Of Education.
See the diagram I attached where the relay in the center is shown attached to pin1, D2 I used 4148, the transister is the 2n3904 and the R1 resisters I tried were 10K, 470ohm.· I connected Vcc to the WAM breadboard Vss and gnd to WAM breadboard Vdd.
The Aromat DS2E-M-DC5V runs at 5v, coil power 400mW, coil 62.5 ohms.
Sid Weaver
Do you have a Stamp Tester yet?
#1. Got ALL the relays I tried - to now work!!!! - directly on the WAM (Homework board): including 4.5v, 5v, and 9v
#2. I'm an idiot: I have now learned to use Vdd for 5v, Vin for 9v, and Vss for ground NOT visaversa!
#3. Learned that the relay coils are polarized and will not activate if wired with the wrong polarity (which is not shown on the Radioshack retail packaging....arg)
#4. Happy Halloween, I'm going crazy with Homework boards, RELAYS!, windshieldwiper motors, Scary Terry Audio Player boards, and skeletons!
Thanks again for your help and giving me a clue! Now you've made me dangerous! Halloween-wise anyways!
