To tin or not to tin
Electronegativity
Hello, I just bought one of those Pulsar home PC board kits.
I know several people who frequent this forum have used these successfully, and I am wondering if you "Tin" the boards or not.
Does it make a difference?
If so, then what product would you reccomend?
-Alexander
I wonder if this wire is hot...
-Alexander
I don't see a bad reason for using this....but I'll let others chime in!
Steve
I have worked primarily with SN96 solders that has a melting point of 700 Deg. Tinning is much more critical when using high temp solders. SN63 is more the type of solder alloy you will be working with which reflows much better. HMP solders are the hardest to reflow and at 800 degrees melting point, if you don't get it right fast you can quickly burn up the component and even the board·as well!
Formally RoboROOKIE.
Post Edited (SN96) : 10/3/2005 4:13:37 PM GMT
Being that I live in a steel making town, the atmosphere is highly corrosive.· So what happens is that a copper board goes from being shinny and fresh to a blacken mess in a short time period.
So, it is really a good idea to tin your boards as they store easily and when you get ready to solder you don't have to scrub off a layer of tarnished copper in order to get a good flow.
Additionally, having that protective layer of tin tends to avoid excessive soldering.· I have tried to tin the whole board with a soldering iron, but it is both tedious and wasteful.
G. Herzog in Taiwan
If your board is not to large, you can hand tin your pads. I hand tin several small boards that are not worth the time and prep of waving especially if it only has two SMT parts on it.
If I hand tin the pads for the SMD components I should be able to hold them down with a tweezer and heat the feet instead of bringing the solder to the heated joint.
I destroyed 3 SX20's this weekend trying to attach them to Sparkfun breakout boards because I globbed on too much solder and bridged accross the pins. Attempts to desolder ended up damaging the fine traces on the boards.
Steve
I do that for DIP stuff but don't know of any chip carriers that would take as SX20.
Do you?
Also, any solder bridges can be removed using the iron but a bottle of flux makes this much easier. The next best thing is to use a solder wick; a copper braided wire. You can even use a piece of striped copper stranded wire, twist it tightly, and then use that to suck any excess solder if you do not have any solder wick.
Do you think pre-tinning the pads would place enough solder to attach a component without adding more later?
Also, why do you use such high temperature solder?
when I solder most things together (specifically connectors and wires) I tin the wire ( in some cases) and the connector I'm going to (just with a tiny bit of soldeR).
This means when I put the two together, the iron only has to melt the solder (which is at a lower melting point than the hardware materials), not heat both connector and wire to accept solder and then fuse together.
Basically, you're seeding both components so that their like parts (the solder) will easily melt together.
Steve
For me, parts with ic's, I hand reflow solder on the pads, and then I use a solder wick to remove the "dome" of solder. I like all my pads flat to allow precision alignment of the ic pins. I would not try to hand solder an ic with solder already on the pad because this makes lining up the ic harder. By adding solder and then removing it with a solder wick will provide the right amount if "tin”. If you are going to store the board for later use, you can leave the solder on thick until you are ready to put on your parts.
Why Such High Temp Solder?
At my work we manufacture drilling equipment for oil wells. These drill bits that contain our electronics under go extreme vibration and heat. We use special ic components that are made out of ceramic to survive extreme temperatures, which is why we use hi temp solders. I personally would use sn63 on my own projects as·low temp solder reflows so well.
Post Edited (SN96) : 10/3/2005 6:11:17 PM GMT
I've been spending so much on toys lately that I have to get to the mailbox first so my wife doesn't see my bank statement.
I'll have to make due with one for now.
I here ya about the bank statement. Here some more advice.... Burn the paper trail!
I use "Liquid Tin" (JDR sells it).
No heating or anything, just immerse the board and it will tin it almost immediately.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
Available now... SX-Video OSD module $59.95 www.sxvm.com
"I'm a man, but I can change, if I have to, I guess"
Red Green
I can understand this very well and it kind-a funny
"I've been spending so much on toys lately that"
I do not have to worry about that i have own my bank account
.....................Now to me this is funny.......................................................
" I have to get to the mailbox first so my wife doesn't see my bank statement"
"I here ya about the bank statement. Here some more advice.... Burn the paper trail!"
See my problem is that i still what to play like a kid
·when it come to my hobbies
I do not want to grow up i still want to play·and spend all weeken do it and this get me·in·trouble( now i do not mean every weeken)· if you what i mean
WHAT I have worry about is when the Wife comes and says loan me some money
and i say i do not any money i bought my play toys like BS2 and the like
She says have you spent enough money on your play toys
Not yet
SAM
Post Edited (sam_sam_sam) : 10/5/2005 12:53:18 AM GMT
