multiple switches for one pin?
I remember seeing this somewhere, about adding multiple switches for one input pin. Can someone refer me to the sources?
Thanks for your help.
Tony A
Tony A
Can't find the exact reference at the moment, but I think the scheme used the RCTIME function. Basically, the resistance seen by the pin was changed as each of several switches opened and closed.
Probably someone will jump in with exactly what you're looking for.
Cheers,
Tom Sisk
Thanks for the info. I didi as search and found what your refered to. It uses a resistor ladder (I think it's called). I wonder if the same thing can be used with piezo discs acting as switches.
I'm trying to get 12 piezos which will act as switches into one pin.
Thanks again,
Tony
