DCM-8 Motor driver circuit
Does anybody know hot to inferace the DCM-8 Motor driver circuit to a stamp. From the specs:
Serial communication with the DCM-8 is done at 9600 baud, 8 data bits, no parity and 1 stop bit (9600-8N1) for TTL seial interfaces.
Command: FF# FF= both motors forward #=(0-9) speed
Im using a stamp stack 2SX so Im using the following code but nothing works:
serStr· VAR···· Byte(3)························
Main:
· serStr(0) = "F"
· serStr(1) = "F"
· serStr(2) = "5"
START
· SEROUT 1, 16468, [noparse][[/noparse]STR serStr\3]
· GOTO START
Main:
· serStr(0) = "F"
· serStr(1) = "F"
· serStr(2) = "5"
START
· GOTO START
Jon Williams
http://www.hvwtech.com/resources.asp?strSearch=&Mode=anywords&rCatID=1&CurPage=1
[url=:startDownload(25)]DMC-8 User Manual (.pdf)[/url]··220KB
#SELECT $STAMP
· #CASE BS2, BS2E, BS2PE
··· T9600······ CON···· 84
· #CASE BS2SX, BS2P
··· T9600······ CON···· 240
· #CASE BS2PX
··· T9600······ CON···· 396
#ENDSELECT
SevenBit······· CON···· $2000
Inverted······· CON···· $4000
Open··········· CON···· $8000
Baud··········· CON···· T9600
Now you can try a test statement, something like:
· SEROUT Motor, Baud, [noparse][[/noparse]"FF9"]
That should make both motors move forward at full speed.· If it doesn't, change the Baud definition to this:
Baud··········· CON···· T9600 + Inverted
... and try again.· Do make sure that you have configured the board for TTL serial input.
Jon Williams
