Analog to Digital Converter — Parallax Forums
sumguy16sumguy16 Posts: 21
edited 2005-09-29 00:38 in General Discussion
I've been reading the documentation on the SX - chips and I saw that a A/D converter is built in. I must be blind because I can't find any documentation or posts regarding this subject, can someone help?
Adam Przybilla
    edited 2005-09-28 22:51
    It does not have an A2D built in, but there are a a few ways you can make one. The latest SX/B help file shows an 8-bit version that uses an RC circuit and the onboard comparator.
    Jon Williams
  • Beau SchwabeBeau Schwabe Posts: 6,574
    edited 2005-09-28 23:08
    Adam,
    What you may be refering to is the description of each of the SX chips....
    The Ubicom SX is a RISC architecture, high-speed microcontroller with flash program memory, in-system programming and debugging capability. Operating at frequencies up to 75 MHz with an optimized single-cycle instruction set, developers can implement real-time functions as software modules. Common examples include communication interfaces (I2C, SPI, UARTs), frequency generation and measurement, PWM, and sigma-delta A/D.
    ...The last sentence starts out by saying "Common examples..." one of those being a sigma-delta A/D
    Beau Schwabe
    IC Layout Engineer
  • sumguy16sumguy16 Posts: 21
    edited 2005-09-29 00:25
    That makes sense, sorry for the confusion.
    Jon, I saw you posted an 8-bit solution with an RC circuit, is it even possible to a 12-bit A2D without an extra IC, space is a bit of a concern for my project.
    Adam
    If you checkout www.sxlist.com (while it's still up) there is a note posted there by a user that he was able to get 12-bit resolution form a Sigma-Delta A2D (virtual peripheral).
    Jon Williams
