H-bridge control I'm trying to convert bs1 text to bs2
' {$STAMP BS2}
··········· ' Program Listing 23.1 BS1 Program to Demonstrate Mondo-Tronics H-bridge
' Program: MONDOMOT.BAS (Demonstrate Mondo-Tronics H-bridge)
' This program demonstrates the Mondo motor controller to
' control the direction and speed of a DC motor. Connect
' input A of the controller to Stamp pin 0; B to pin 1; and
' GND to GND. Run the program. The motor will slowly accelerate
' to top speed, then stop and repeat the acceleration in
' reverse. This program uses a carry-the-1 method of generating
' duty cycle control of motor speed. When you add a number to an
' "accumulator" (a memory location of fixed size), the accumulator
' will overflow if the result is bigger than it can hold. The
' larger the number added, the more likely an overflow or "carry"
' is. This program adds the desired motor duty cycle to an
' accumulator, and turns the motor on only when there's a carry.
' Higher duty cycles make the motor run faster. This method works
' well with the Stamp because it is more or less independent of
' speed.
motAcc VAR Byte··· ' Motor-speed "accumulator.
motDir VAR Byte····· ' Motor direction: 0=fwd; 1=reverse.
spd VAR Byte···· ' Motor speed, 0 (off) to 15 (full on).
cycles VAR Byte··· ' Number of loops at a given speed.
A CON 0····· ' Controller A input.
B CON 1····· ' Controller B input.
INPUT 0
INPUT 1
DIRS = %11······ ' Set pins 0 and 1 to output.
again:
· FOR cycles = 0 TO 255·· ' Turn 255 cycles at each speed.
·· GOSUB motor···· ' Output to motor.
· NEXT
· spd = spd +1···· ' Increase speed.
· IF spd <= 15 THEN again·· ' If speed is > 15, then..
· spd = 0······ ' ..turn motor off..
· motDir = motDir ^ 1···· ' ..and reverse direction.
GOTO again·· ' Loop forever.
motor:
· motAcc = motAcc & %1111·· ' Limit motAcc to 4 bits.
· motAcc = motAcc + spd·· ' Add speed.
· IF motAcc >= 16 THEN motOn·· ' If carry, then turn on motor.
·A = B ' Otherwise, motor off.
' GOTO again
· RETURN
' If you look at the table accompanying the H-bridge, you'll
' see that the motor is on only when inputs A and B are opposite.
' Programming shorthand for this is to set A to the motor
' direction, and make B = NOT A. PBASIC1 does not have a NOT
' function per se (see LET in the manual), so we make do by
' XORing A with 1, which has the same effect: B = A ^ 1.
motOn:
· A = motDir: B = A ^ 1
RETURN
· ' GOTO again
' speed.
INPUT 0
INPUT 1
again:
· NEXT
motor:
' GOTO again
· RETURN
motOn:
RETURN
· ' GOTO again
Converting from BS1 to BS2 code is really easy to do, not much work involved really.
Is the BS1 code running like you need it to/want it to?
Ryan
Ryan Clarke
RClarke@Parallax.com
Lance
It may be that you received some code in private by email which answered this thread. Don't know why there was nothing more posted.
The·idea of controlling an H-Bridge directly with a stamp has had my interest for a while so I finally experimented with some small 6v motors on a "Professional Development Board".·The circuit used the BS2, all 8 dip switches, and the L293D (the new PDB is great!). There is an·ASCII·drawing of the circuit in the code.
I suppose that this circuit and code could be used in hobby robotics, but if I were to use it I would dedicate a BS2OEM as a slave to a main controller. A pin multiplexer could be used to send the two 4 bit speed signals to the BS2OEM so that the main controller would have plenty of free pins and be able to do the sensor work.
The PWM frequency needs to be much faster than the 39Hz that this PWM cycle was measured at.
The attached PBasic BS2 code is not a conversion of the code that was posted for the BS1. It is a redesign.
Post Edited (Russ) : 10/4/2005 5:13:15 AM GMT
