trouble with 9 bit math; controlling overflow
hail
the project:
in a continous rotation drive one encoder returns command (where do i want the drive to point), another returns feedback (where the drive is pointing). the controller compares the 2 encoders w/ a simple algorithm and turns the drive so that the feedback matches the control.
the algorithm:
if command = feedback then dont move
if command - feedback < feedback - command then turn clockwise
if command - feedback > feedback - command then turn counterclockwise
the trouble:
the encoders have 512 bits of resolution, to simplify the project i ignored the lsb and voila. the algorithm applies directly to the sx because the byte sized variable wraps around itself. that is
1 - 255 = 2
255 - 1 = 254
so go clockwise.
but i think i can do better! i can do this with 9 bits.... ok i cant because i'm stuck on this snippet
; btw testcw = cmd
mov w, feedback0 ; testcw = cmd - fbk
sub testcw0, w
mov w, feedback1
sc
movsz w, ++feedback1
sub testcw1, w
the result is true 16bit and wraps around 65535, but i need it to wrap around 511. my previous sub wrapping script would dec the variable in a loop and detect for overflow. but thats way to slow.
does anyone have any experiance with this?
any help would be well received.
i attached 2 files,
apec256 is the working 8b program and is well commented
apec512 is the partial program in question and is poorly commented
future thanks for your generous reply
nickB
engineer, fireman, bowler, father, WoW addict [noparse];)[/noparse]
the project:
the algorithm:
the trouble:
1 - 255 = 2
255 - 1 = 254
so go clockwise.
; btw testcw = cmd
sub testcw0, w
mov w, feedback1
sc
sub testcw1, w
i attached 2 files,
nickB
rotosub_9bit
cjb value1, result1, r9_no_overflow ; if v > r then overflow
cjb value0, result0, r9_no_overflow
; on overflow r = r + 512 - v
or result1, #$02 ; r = r + 512
r9_no_overflow
mov w, value0 ; r = r - v
sub result0, w
mov w, value1
sc
movsz w, ++value1
sub result1, w
ret
edit - that doesnt work the conditional jumps fail. try,
rotosub_9bit
cja xvalue1, xresult1, r9_overflow ; if v > r then overflow
cjb xvalue1, xresult1, r9_no_overflow ; if v > r then overflow
cja xvalue0, xresult0, r9_overflow
jmp r9_no_overflow
r9_overflow ; on overflow r = r + 512 - v
or xresult1, #$02 ; r = r + 512
r9_no_overflow
mov w, xvalue0 ; r = r - v
sub xresult0, w
mov w, xvalue1
sc
movsz w, ++xvalue1
sub xresult1, w
ret
Post Edited (nick bernard) : 9/28/2005 7:55:35 PM GMT
Tracy Allen
www.emesystems.com
my algorithm goes like so
if valHi > valLo then
result_cw = valHi - valLo
result_ccw = 512 - (valHi - valLo) = 512 + valLo - valHi
yours states mask = $01
result_ccw = valLo - valHi // 512 = [noparse][[/noparse]calculator] ((65536 + valLo - valHi) / 512 - 127) * 512
66536 + valLo - valHi - 65024 = 512 + valLo - valHi
512 == 512 *SUCCESS*
so you can also div by the wrap around value to do circular arithmatic! i honestly did not think it was that simple
many thanks tracy
Post Edited (nick bernard) : 9/29/2005 2:04:13 PM GMT
