real quick help — Parallax Forums
real quick help
akezakez Posts: 12
edited 2005-09-28 18:30 in General Discussion
I have a board of education and i want it to work with my basic stamp editor. I have the serial feed one not the usb one. I also have Windows XP and i can't seem to get it to find the stamp. is it suppose to find it automatically or do i have to install some drivers or maybe switch a setting..plz help..thanks
akez
Post Edited By Moderator (Chris Savage (Parallax)) : 9/27/2005 11:47:43 PM GMT
  • NewzedNewzed Posts: 2,503
    edited 2005-09-27 23:38
    The Stamp Editor does not recognize a Stamp until you down load a program.· Is that what you are trying to - download a program?
    The is an "ID" icon in the Editor toll bar.· If you have your Stamp connected via serial cable and it is on, click on the ID icon and see what the screen tells you.· Under Edit/Preferences/Editor Operation make sure the Default Com Port is set to AUTO.
    Sid Weaver
    Do you have a Stamp Tester yet?
  • akezakez Posts: 12
    edited 2005-09-27 23:44
    It is set to auto and whenever i try to run my program it says "basic stamp not found". i really wish i could get this working
    Post Edited By Moderator (Chris Savage (Parallax)) : 9/27/2005 11:47:51 PM GMT
    edited 2005-09-27 23:50
    What does the screen say when you click on the ID icon?
    Sid Weaver
  • FreezeSukkaFreezeSukka Posts: 41
    edited 2005-09-27 23:58
    Is the power "on" on the stamp itself?· I think I've gotten that message before and that was my problem.
    ~Jeff
    P.S. This is what this part of the alphabet would look like if "Q" and "R" were eliminated.
    edited 2005-09-28 17:18
    the com port is set alright. and the power goes on automatically..still lost
    Post Edited By Moderator (Chris Savage (Parallax)) : 9/28/2005 6:21:52 PM GMT
  • SN96SN96 Posts: 318
    edited 2005-09-28 17:43
    You might want to check the battery if it uses one. I thought I fried my basic stamp because it would not recognize the stamp as you have explained. even weirder was the battery seemed to have power but apparently not enough to make things work. I replaced the 9-volt battery and wala, everything work perfectly.
    akez,
    ·· A private message was sent regarding your posts.· Please check your private messages.
    csavage@parallax.com
