Parallax Professional Development Board & MAX232E
Received the PDB a couple of days ago, and have to say this is great so far. Where I have managed to test most of the functions have hit a snag on using the MAX232.· Can anyone share a short example for using the MAX with a BS2 just to confirm it’s working with the PDB? ·Thanks.
Cheers, Michael
Cheers, Michael
If you add another serial port [noparse][[/noparse]let's say you have a Serial LCD that uses RS-232], you can configure the second serial port to run through the MAX232.
The signals to/from the BS-2 are TTL [noparse][[/noparse]which are 0 V and +5 V] while the signals to/from the RS-232 side of the MAX232 are +10 Vand -10 V]. This higher voltage allow you to have long wires. Also, the MAX232 is set up for two recieve and two transmit lines. If you want, you can add hardware control on PINs 7 and 8 of you DB-9 connect for a 4-wire interface. Alternatively, you can have two separate 2-wire RS-232 ports.
G. Herzog in Taiwan
Just note that when you're talking to the max232's TTL lines...you should be in TRUE baudmode...whereas you would be in INVERTED baudmode if you were listening to rs232 lines (don't forget your inline resistor for safety -- 220ohm I believe)
Steve
Jon Williams
Jon Williams
