Stupid question #2 - Large arrays in memory
Ok, I'm starting to feel really dumb now...
I have an 64 byte array of memory and am having difficulties addressing it.
The problem is the very small 16 byte memory pages offset by the 16 byte global registers.
I love the global registers, but allocating the memory and accessing a continous block across them is a PITA.
Example:
ORG 0x10 ;Start after all the global registers
BigArray ds·0x40 ; Define my big array - 64 bytes long
mov W, #BigArray+20 ; Lets try to get offset = 20
mov FSR, W· ;Setup the FSR
mov W, INDF· ; Oops!· Not even close!
Since BigArray +·20 = 0x24 the FSR rolls over at 0x20 and splat I'm left accessing 0x04.
I have something that is working but it is a major cycle hog.· For this app speed is king.· Before I set to work to slim it down I thought I'd see what you all had to say - I'm probably missing something fairly straightforward.
Eric
Post Edited (Up2l8) : 9/25/2005 10:18:02 PM GMT
Example:
Eric
A bit messier to index, but it was all I could come up with for the time being.
Eric
So if you have an array of 32 bytes starting at $10 and you are retreiving the 23rd element, 23/16 = 1 remainder 7. The memory location is $10 + $20 + $07 = $37.
<note> changed equation, should be correct now </note>
·1+1=10
Post Edited (Paul Baker) : 9/26/2005 5:46:23 AM GMT
······ mov w, <>Index
·······and w, #$0F
······ mov IDiv, w
and the remainder is simply
······ mov w, Index
······ and· w, #$0F
······ mov RDiv, w
·1+1=10
I had something similar to that eventually but I think that I was being dumb and trying to make an address => address mapper instead of an index => address mapper.
What you posted makes much more sense [noparse]:D[/noparse]
I'm afraid that it still might be too time consuming though - that adds 7-8 cycles per read/write.
I suppose you trade code space for cpu time though...
Eric
Post Edited (Up2l8) : 9/26/2005 4:11:43 PM GMT
·1+1=10
Inside the timing critical loop the data is incremental read only so just incrementing the pointer is much quicker than decoding the index every time.
Your solution is much more practical for random access type stuff.
Eric
In essence after you increment the pointer you do:
········ setb dptr.4 ;SX28 bank wrapping adjustment
and after decrementing is
········ jb·· dptr.4, :noroll ;SX28 bank wrapping adjustment
··········· sub dptr, #16
:noroll·························;rest of code
dptr is the index (which must be placed in FSR before indirect access)
·1+1=10
Post Edited (Paul Baker) : 9/27/2005 12:36:38 PM GMT
