Cigar Box Robot Arm
Behold the cigar box robot arm!
This is a robot arm that I made and mounted on a cigar box. The project has a BS2 and Parallax Servo Controller mounted on a sheet of plexiglass. The BS2 is mounted with 2 solderless breadboard. There is a remote control with 4 potentiometers mounted in a small project box and connected to the main board with a wire which is routed through the bottom of the cigar box. I use a custom serial to 4-pin header to program the BS2 and I can remove the main board from the box so that it is easier to work with the components. Attached are a few pics (sorry, but the close up pic is a little blurry).
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
Post Edited (Dave Andreae (Parallax)) : 9/26/2005 9:11:47 PM GMT
-Marc
any way I am curious what is the project in the back ground with the magnetic strip reader.
sucess is when you fail and try again
·-Churchill
-Marc
