Need help finding small ball and socket joints...
Hello fellow bot'ers...I have been all around the web and cannot find a small "ball and socket" joint.· Something with a total "inline" length of about 1 to 2 inches long.· One end needs to be threaded, female, and the other end could be the same, but it would be better if the opposite end of the threaded female end would be some sort of mounting flange.
The ball joint itself could be any size from 1/2 inch diameter to 1 inch·diameter.· The max angle doesn't need to be over 20 degrees.
If you have a source, please email me at:···denogail@jackpine.com.
Thank you
deno
Thank you
deno
Take a look at the Tower Hobbies web site:
http://www.towerhobbies.com/
Search for "ball socket" and you should find some fittings.
Bruce Bates
Any other suggestions?
Thanks Deno
Do you need that 20 degrees of flexibility through a range of 360 degrees or something less than that? In other words (by way of example) does the "joystick" have an infinite number of gates, or would 2, 4, 8, or 16 be enough? ( | , --- , X, *, etc). If you DO need a joystick mechanism, please say so, as that's a good deal easier to find.
How much weight (if any) will this joint be expected to support?
Bruce Bates
The company offers a free catalog and provides a good website.
Post Edited (bobledoux) : 9/26/2005 1:04:06 PM GMT
