USB to serial
I have a USB to serial cable that I got about 2-3 months ago and then just got the Discovery kit with the BOE and such. When trying to program / identify the BS2 it can not find it.
Has anyone had similar problems? It should seem that it shouldn't matter what kinda of usb to serial converter you would have, its just sending serial data right?
Is it a reqiurment to use the usb to serial converter that parallax sells on their site? Or are there any other lower cost alternatives or would it be possible to use their drivers or something?
http://www.parallax.com/dl/docs/prod/acc/USBInstallWinXP.pdf
Note that XP is a little funky and will sometimes ask you to do the installation twice; after the second time all will be fine.
Jon Williams
It gives you full control of all handshake lines, too.
I'm sure the FTDI works just as well, if not better, but I haven't personally used it with VB.· There's no reason it shouldn't work, though.
Post Edited (allanlane5) : 9/24/2005 8:54:21 PM GMT
Jon Williams
The ports are "there" i can go in to my device manager and it says that it is there it just can not find the Stamp...
Any suggestions... or am i left with getting the FTDI adapter?
Jon Williams
To borrow part of your message, here's the way I understand it:
You can buy a any number of "low cost alternative" devices which call themselves USB to Serial adapters that meet some of the easier to meet RS-232 specifications, or you can buy a worthwhile USB adapter, which meets or exceeds ALL the RS-232 spcifications to "get my bs2 to work with my laptop", but you can't do both. Regardless of whether they've used it for Stamp programming or not, I've never heard of anyone who was unhappy with the USB to serial adapters that Parallax recommends. On other programming forums, I've even seen it said "Get the FTDI adapter - Parallax uses them, and I'm sure you can't go wrong with it".
I've often felt that folks confronted with this USB-to-Serial adapter quandry are somewhat irked, or put off by having to purchase something "special" to program the Parallax Stamps, so let me say this. In the over ten years I've been dealing with Parallax, I've never seen them recommend or require anything that wasn't absolutely necessary, and what they recommend, whether purchased from them or not, is of the highest quality necessary to get the job done, and no more costly than that. I'm reasonably sure no one at Parallax is getting rich selling USB to Serial Adapters
Bruce Bates
Sid Weaver
Do you have a Stamp Tester yet?
