testingngngnggg "[" and "]"
test "[noparse][[/noparse]" and "]"
This does not work properly in my browser. I do not know why.
Post Edited (diafysal) : 9/23/2005 10:35:01 PM GMT
System.out.print(buff[noparse][[/noparse]0]);
System.out.print(buff);
/* Simple test program to Identify Firmware Version Number.
* From "ServoController.pdf"
*(please improve the coding)
* diafysal
import stamp.core.*;
public class test_ver {
public static void main() {
char [noparse][[/noparse]] buff;
buff = new char; // data from PSC
Uart myUart = new Uart(Uart.dirTransmit,
CPU.pin0, // Serial Data I/O pin
Uart.dontInvert,
Uart.speed2400,
Uart.stop2);
while(true) {
System.out.println("Finding PSC");
myUart.sendString("!SCVER?"); //send command
myUart.sendByte(0x0D); //end of command
while (!myUart.sendBufferEmpty()) ; //wait for buffer empty
myUart.setDirection(Uart.dirReceive); //change direction
buff[noparse][[/noparse]0] = (char)myUart.receiveByte(); //receive response
buff = (char)myUart.receiveByte();
myUart.setDirection(Uart.dirTransmit); //change direction
System.out.print("PSC ver: ");
CPU.delay( 30000 ); // Long delay
System.out.print('\u0010'); // Clears the terminal
} // end while
} // end main
} // end class declaration
Jim
Parallax IT Dept.
Jim
Parallax IT Dept.
Jim
Parallax IT Dept.
Jim
Parallax IT Dept.
Why does "[noparse][[/noparse]" and "]" disappear in my browser?
Jim
Parallax IT Dept.
When I look at the tread only the square brackets [noparse][[/noparse] ] with a "0" inside is shown.
The one with 1,2 or 3 inside does not show.
I'm using Firefox 1.0.6
(edit)
hmmm
Post Edited (diafysal) : 10/3/2005 8:54:28 PM GMT
[noparse][[/noparse]0] - [noparse][[/noparse] zero ]
- [noparse][[/noparse] one ]
- [noparse][[/noparse] two]
SX-Key + SX52 + Proto Board + SX-Key Software + Computer + USB to Serial Adapter + LED = Blinky LED!
ENIAC: P4 2.8ghz E, 1024MB PC3200 Dual Channel 800MHZ, P4C800E-Deluxe, ATI X800XL, 120GB Sata WD HDD, Audigy 2 ZS Sound, AMG 1080 Antec case, Bose TriPort Headphones.· Running on Windows XP Pro SP 2.
Perhaps you meant to end your post with "; - )" instead ?
