what is a good general purpose NPN transistor
Hi all, what is a good general purpose NPN transistor to use for switching 5V current with an SX microcontroller?
Maybe this belongs in the SX forum, but it seemed more like a general electronics question.
Post Edited By Moderator (Chris Savage (Parallax)) : 9/23/2005 7:32:50 PM GMT
·· The 2N3904 and the 2N2222 are the more common NPN experimenter/hobbyist transistors.· You just need a resistor between the I/O line and the base of the transistor to use it.· The value depends on what load you're driving, but generally a 220 ohm to 1K works.· In prototyping and using the transistor as a switch, I always use a 1K.· You can calculate for the correct value though if you want to be exact.
csavage@parallax.com
I wonder if this wire is hot...
The subject line was not a mistake.
Transistor is a contraction of "transfer resistor."
I am filling out an order from Mouser to stock up on general purpose parts, but their selection of transistors is so huge that I figured it would be better to ask then just order random stuff.
