Which board??????????
I am trying to find·proper board for a BS2.· I have an agricultural application, thus the·stamp is going to be bounced around on a piece of equipment in a rough crop field.· I need a board where I can easily connect and disconnect from the PINS.· Hopefully with a terminal strip and a phillips head screw to tighten down the wires for the I/Os.
Thanks for your help.
csavage@parallax.com
·· Can I add something to an order I placed about an hour ago?
Jon Williams
·1+1=10
Is is it safe to assume it is 12 volt dc stuff on the·AG equipment?
How much I/O do you need?
Let me know I may be of some help to you.
Alan Bradford
Plasma Technologies
www.plasmatechnologies.com
Thanks for your help?
·Could you explain your appication in more detail? Is the encoder for reading a shaft position, or a control knob? What type of RF interface is used?
The controller will run on AC or DC input from 10-35 Volts. I have used it with the Stamp-2 and 2p-24. I have not used a Javelin Stamp, but I will order one and make sure it works too.
It has 16 I/O positions to put a Solid State I/O module. You can mix and mach AC or DC, Input or Output modules.
It is a machine controller. Most industrial machinery uses·switches and valves/motors to run. This controller was designed for that type of operation. Conveyors, Welders, Fabrication and Assembly Lines·are all in this category. This differs from a process controller, in that process control is more analog in nature. Move this piece in the oven until it reaches a certain temperature, or measure the ph of a solution being mixed. This is process control. and not addressed by my controller.
A picture of·one of my early boards, installed in Phoenix and still in service,·is posted in the projects section. The post is General Purpose Controller Board.
There are 2 boards in that post. The one I am describing (posted 09/16) and the one that Tom Sisk has developed.
Take a look.
Alan Bradford
Plasma Technologies
In areas where cotton is grown when it is harvested it is dumped into a "module builder."· The module builder is basically a moible metal·box with movable press to compress the cotton into a roughly 6' wide x 8' tall x 22' long module for hauling by a live bottom truck.· See the picture below.·
The encoder is an input and will be shaft mounted to tell the stamp when the press has moved a measured distance which changes throughout the program.· ie "Move press AWAY 3 feet by listening to the encoder."
The RF I am planning on using is:
The RF remotes are so when we drive up to the module builder we can stop the program, dump a load of cotton, and start the program again without leaving the tractor seat.·
I think that answers what you were asking.
Andy
This is a good application for a machine controller. The encoder could be as simple as a Hall sensor counting teeth on a gear.
The controller can be made to read all the I/O you are looking for.
I am looking for someone to beta test the board. I have used them for years, but I am also my only customer. Some outside feedback would be nice.
Contact me if you are interested.
Alan Bradford
Plasma Technologies
